Multiple VLANs under one HptSpot
How to configure a Single HotSpot with multiple VLANs, Which helps to provide different login screen based VLANs and allow the user device without re-login while roaming across VLANs.
@rasantwrk
Can you describe in detail what exactly you would like to achieve?
How do you want to roam across VLANs?
Hi, we can run multiple Hotspot servers on each VLAN, but re-authentication occurs when a user moves from one VLAN to another. For example, if a user logs in on VLAN 10 and then moves to VLAN 20 within the building, their internet connection is disconnected and reconnected after authentication. The plan is to avoid this re-authentication by setting up a single Hotspot that serves multiple VLANs.
How do you want to control which VLAN is used for a particular hotspot?
only one HotSpot for all L2 VLANs, Even can show different authentication based on VLAN numbers also
