multiple VPN's between cisco 2811 and RB450's
Hello people, who can help me with information, how i can connect
multiple RB450’s with Cisco2811 in VPN with encryption.
I can’t find infos.
I try to connect via IPSEC, but it work only with one tunnel.
I try to use the VTI, but after some period, mikrotik loose the link,
it work 2-3minutes…
More detail required. How about posting your IPSEC configuration from each end?
Kind regards
Andrew
if you have typical config’s for MT and CISCO, i will glad to use it…
hi, have you any solution for connecting rb400 with more than one Cisco 2811 router ?
