Multiple WAN IP/Interface troubleshooting
Hardware: CCCR1009
Physical connections:
  • SFP+ connected as trunk for multiple vlans back to a switch
  • Eth6 connected to WAN
  • Eth5 not connected currently but will eventually be a second wan link to same gateway/subnet with a subset of the WAN IP’s I have been assigned
Local IP’s for the config are all in 10.0.0.0/8 range,
Allocated WAN IP’s are x.x.x.120-127.
WAN IP x.x.x.120 is the current default route IP which works fine, including dstnat.
What I want to achieve:
CCR is intended to do inter-vlan routing for VMware/management and vm traffic which is all connected to the switch. Note I do not yet have a rule setup to block traffic between VLAN’s as I’m still working on the WAN side of it but that I know how to achieve.
I want to use multiple WAN IP’s in the same subnet, using the same gateway setup across multiple interfaces to ensure some large file transfer traffic doesn’t affect some other traffic (multiple interfaces isn’t a priority right now but it probably will mean certain things need doing differently)
I want to have some local IP’s to be routed out to the internet using different wan IP’s for external traffic.
I also want to dstnat certain ports on certain WAN IP’s to some local IP’s.
What I have done so far:
What I have is one gateway from the ISP/colocation host with a /29 range of public IP’s to use, the gateway sits outside that range however at x.x.x.1
I followed the setup guides with regards to srcnat/firewall filter rules and everything works fine as a standard firewall/router setup with 1 WAN IP.
I have added a new WAN IP to the WAN if (eth6) and found I couldn’t ping it from the internet as I can the original WAN IP of .120.
I have also set a dstnat for port 443 to the .121 WAN IP and when I send any requests to that IP on the port I don’t see anything on the traffic counter like I would expect.
I created a new default route on a different routing table/routing mark called 121ip-out. This rule had the pref-src set to the x.x.x.121 WAN IP.
I then created a routing policy to force a lookup on the main routing table for any internal-internal traffic. Then a second rule to match a local source IP and force a lookup on that new routing table to make it use the new default route.
I’m sure I’m missing something here, any advice is appreciated.
I would also like to eventually add half of the WAN IP’s to the second WAN if. Will that complicate things?
Config is attached to fill in any gaps/details I have missed.
# jan/19/2023 20:51:56 by RouterOS 6.46.7
# software id = KSLP-3I77
# model = CCR1009-7G-1C-1S+
# serial number =
set [ find default-name=sfp-sfpplus1 ] name=SFP+Trunk
/interface vlan
add interface=SFP+Trunk name=vlan15-D vlan-id=15
add interface=SFP+Trunk name=vlan20-R vlan-id=20
add interface=SFP+Trunk name=vlan30-Common vlan-id=30
add interface=SFP+Trunk name=vlan99-MGMT vlan-id=99
add name=WAN
add name=LAN
add name=AllVLAN
add name=DHCP-MGMT ranges=10.10.99.50-10.10.99.100
add name=D-DHCP ranges=10.10.15.50-10.10.15.100
add name=OVPN-Pool ranges=10.10.60.1-10.10.60.50
add name=Common-DHCP ranges=10.10.30.100-10.10.30.200
add name=vpn-isec ranges=10.10.85.50-10.10.85.100
add address-pool=DHCP-MGMT disabled=no interface=vlan99-MGMT name=MGMT-DHCP
add address-pool=D-DHCP disabled=no interface=vlan15-D name=Dann-DHCP
add address-pool=Common-DHCP disabled=no interface=vlan30-Common name=\
    Common-DHCP
/ppp profile
set *0 local-address=10.10.85.1 remote-address=vpn-isec
/interface l2tp-server server
set default-profile=default enabled=yes use-ipsec=required
add list=LAN
add interface=ether5 list=WAN
add interface=ether6 list=WAN
add interface=vlan15-D list=LAN
add interface=vlan20-R list=LAN
add interface=vlan30-Common list=LAN
add interface=vlan99-MGMT list=LAN
add address=10.10.99.1/24 interface=vlan99-MGMT network=10.10.99.0
add address=10.10.30.1/24 interface=vlan30-Common network=10.10.30.0
add address=10.10.15.1/24 interface=vlan15-D network=10.10.15.0
add address=10.10.20.1/24 interface=vlan20-R network=10.10.20.0
add address=x.x.x.120/24 interface=ether6 network=x.x.x.0
add address=x.x.x.121/24 interface=ether6 network=x.x.x.0
/ip dhcp-server lease
add address=10.10.30.100 client-id=\
    ff:bc:9a:4a:2d:0:2:0:0:ab:11:7f:d8:65:bf:16:cc:5c:2d mac-address=\
    00:0C:29:7C:1D:7F server=Common-DHCP
add address=10.10.15.0/24 dns-server=10.10.15.1 gateway=10.10.15.1 netmask=24
add address=10.10.30.0/24 dns-server=10.10.30.1 gateway=10.10.30.1
add address=10.10.99.0/24 dns-server=10.10.99.1 gateway=10.10.99.1 netmask=24
set allow-remote-requests=yes servers=8.8.8.8
add action=accept chain=input dst-port=1701,500,4500 in-interface-list=WAN \
    protocol=udp
add action=accept chain=input in-interface-list=WAN protocol=ipsec-esp
    "Accept established, related, untracked" connection-state=\
    established,related,untracked
add action=drop chain=input comment="Drop invalid" connection-state=invalid
add action=accept chain=input comment="Accept ICMP" protocol=icmp
    "Drop anything that is not from LAN interface" in-interface-list=!LAN
add action=fasttrack-connection chain=forward comment=fasttrack \
add action=drop chain=forward comment="drop invalid" connection-state=invalid
add action=drop chain=forward comment="Drop all from WAN not DSTNATed" \
    connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat out-interface-list=WAN src-address=\
    10.10.15.0/24
    10.10.20.0/24
    10.10.30.0/24
    10.10.2.0/24
    10.10.99.0/24
add action=dst-nat chain=dstnat comment="Plex port forward" dst-address=\
  x.x.x.120 dst-port=32400 log=yes log-prefix="Plex forward" protocol=\
    tcp to-addresses=10.10.15.2
add action=dst-nat chain=dstnat comment="Prox01 - HTTP" dst-address=\
   x.x.x.120 dst-port=80 protocol=tcp to-addresses=10.10.15.4 to-ports=\
    80
add action=dst-nat chain=dstnat comment="Prox01 - HTTPS" dst-address=\
   x.x.x.120 dst-port=443 protocol=tcp to-addresses=10.10.15.4 \
    to-ports=443
add action=dst-nat chain=dstnat comment="OpenVPN vpn01 port forward - 443" \
    dst-address=x.x.x.121 dst-port=443 protocol=tcp to-addresses=\
    10.10.30.100 to-ports=443
add action=dst-nat chain=dstnat comment="OpenVPN VPN01 - 943" dst-address=\
   x.x.x.121 dst-port=943 protocol=tcp to-addresses=10.10.30.100 \
    to-ports=943
add action=dst-nat chain=dstnat comment="Tailscale UDP port forward" \
    dst-address=x.x.x.120 dst-port=41641 protocol=udp to-addresses=\
    10.10.15.3
add action=dst-nat chain=dstnat comment="TMP RDP" dst-address=x.x.x.120 \
    dst-port=3389 protocol=tcp to-addresses=10.10.15.53
add comment="121 ip default route" distance=1 gateway=x.x.x.1 pref-src=\
  x.x.x.121 routing-mark=121ip-out
add distance=1 gateway=x.x.x.1
add distance=1 dst-address=10.10.1.0/24 gateway=10.10.15.3
/ip route rule
add action=lookup-only-in-table comment=\
    "All interVLAN traffic use main routing table" disabled=yes dst-address=\
    10.10.0.0/16 src-address=10.10.0.0/16 table=main
add action=lookup-only-in-table comment="VPN Server External IP .121" \
    disabled=yes routing-mark=121ip-out src-address=10.10.30.100/32 table=\
    121ip-out
/lcd
set time-interval=hour
/ppp secret
add name=admin
/system clock
set time-zone-name=Europe/London
/system identity
set name=RTR01
