Multiple WAN IPs with same gateway
Hi guys,
currently my mikrotik is connected via l2tp to another one to interconnect my datacenters.
Now, i want to use the mikrotik which is configured as l2tp-client to use another wan ip address to use it for natting traffic with dst-nat to virtual machines.
Following a short overview of the ips:
  1. IP: 88.***.8.89/29 on interface ether1
    with virtual mac
  2. IP 88.***.8.88/29 on interface ether5-88
    with another virtual mac
GW of booth ips is 88.***.8.65
If i set the second ip, the first one will become unreachable and the vpn-connection will terminate, because router os will add another default route via the second interface.
So i want to use the first ip only for vpn interconnection and management of router os and the second one only for NAT.
Can someone assist here?
Greetings
Philipp
