At a customer I have a CCR with 3 x WAN and 3 x LAN. In this situation I would like to link each LAN to an own WAN IP address.
Public IPs:
2.2.2.2/29 - ether10
4.4.4.4/29 - ether11
6.6.6.6/29 - ether12
Internal IPs:
10.0.0.1/16 - ether1
10.10.0.1/16 - vlan10
10.20.0.1/16 - vlan20
NAT:
10.0.0.1/16 → 4.4.4.4/29
10.10.0.1/16 → 2.2.2.2/29
10.20.0.1/16 → 6.6.6.6/29
Now I want to make sure that 10.0.0.1/16 goes out on ether11, 10.10.0.1/16 on ether 10 and 10.20.0.1/16 on ether12, all with NAT to the public IP. I have already created a configuration that ensures this. So if you are on vlan10 for example, you have public IP address 2.2.2.2.
Now the problem is: on the 10.0.0.1/16 subnet there are several servers. This servers need to be reachable from the other subnets. The strange this is, from 10.20.0.1/16 I can reach the 10.0.0.1/16 subnet without any problems. But from the 10.10.0.1/16 any request to the 10.0.0.1/16 subnet is routed to the public WAN gateway.
add address=10.0.0.1/16 interface=ether1 network=10.0.0.0
add address=10.10.0.1/16 interface=vlan10 network=10.10.0.0
add address=10.20.0.1/16 interface=vlan20 network=10.20.0.0
add address=2.2.2.2/29 interface=ether10 network=2.2.2.0
add address=4.4.4.4/29 interface=ether11 network=4.4.4.0
add address=6.6.6.6/29 interface=ether12 network=6.6.6.0
/ip firewall mangle
add action=mark-connection chain=input in-interface=ether11 \
new-connection-mark=WAN1_conn
add action=mark-connection chain=input in-interface=ether12 \
new-connection-mark=WAN2_conn
add action=mark-connection chain=input in-interface=ether10 \
new-connection-mark=WAN3_conn
add action=mark-routing chain=output connection-mark=WAN1_conn \
new-routing-mark=to_WAN1
add action=mark-routing chain=output connection-mark=WAN2_conn \
new-routing-mark=to_WAN2
add action=mark-routing chain=output connection-mark=WAN3_conn \
new-routing-mark=to_WAN3
add chain=prerouting dst-address=6.6.6.0/29 in-interface=vlan20
add chain=prerouting dst-address=4.4.4.0/29 in-interface=ether1
add chain=prerouting dst-address=2.2.2.0/29 in-interface=vlan10
add action=mark-connection chain=prerouting dst-address-type=!local \
in-interface=ether1 new-connection-mark=WAN1_conn
in-interface=vlan10 new-connection-mark=WAN3_conn
in-interface=vlan20 new-connection-mark=WAN2_conn
add action=mark-routing chain=prerouting connection-mark=WAN1_conn \
in-interface=ether1 new-routing-mark=to_WAN1
add action=mark-routing chain=prerouting connection-mark=WAN3_conn \
in-interface=vlan10 new-routing-mark=to_WAN3
add action=mark-routing chain=prerouting connection-mark=WAN2_conn \
in-interface=vlan20 new-routing-mark=to_WAN2
add action=masquerade chain=srcnat out-interface=ether10
add action=masquerade chain=srcnat out-interface=ether11
add distance=1 gateway=4.4.4.1 routing-mark=to_WAN1
add distance=1 gateway=6.6.6.1 routing-mark=to_WAN2
add distance=1 gateway=2.2.2.1 routing-mark=to_WAN3
add distance=2 gateway=6.6.6.1
add distance=3 gateway=2.2.2.1
