multiple wan mutiple vlan
Hi networking warriors,
newbie with mikrotik and would like to know if a switch or router can achieve something like in my picture.
If yes how ??
THANK you.
Hey
Technically, any Tik can do that, BUT it is not recommended on CRS as it’s main purpose is switching not routing. What kind of uplink are you talking about bandwidth-wise?
Hi, thanks for your reply, it’s a 300 Mbps fiber.
I’ll use a RB then I guess.
Could anybody help me achieve that ?
I come from ubiquiti products. I’ve been told Mikrotik is the way to go (cost and efficiency wise) if I want to achieve whatever I want with a network.
Thing is it’s all new to me, there is so much parameters, I’m kind of in the middle of nowhere…
Might be just doable, see https://mikrotik.com/product/crs328_4c_20s_4s_rm#fndtn-testresults
Look at “Routing 25 ip filter rules” for 1518B & 512B packet sizes. Both results with 100% cpu usage.
