Multiple WAN!!
Hello all,
I have 3 ADSL connection each 1Mbps. Can anyone tell me that can I make
1+1+1=3Mbps
Is that so, please reply with code.
Also, I read about PCQ, please explain PCQ in simple words.
Thanks,
You cant make 3Mbps connection, unless you control the other end.
PCQ = Per Connection Queue is a queue type capable of dividing traffic into sub-streams based on selected classifiers.
What do you mean by other end??? ISP…
Yes, so if you have 3 x ADSL connections, and the provider wont work with you to aggregate the links, you cant do it alone. You can use PCC to separate connections and spread them over the 3 connections.
http://forum.mikrotik.com/viewtopic.php?f=2&t=37700&hilit=+speedtest
Take a look, May be useful !
