Multiple WiFi Interfaces
As many others are I am using a GrooveA 52 as a WiFi receiver on a boat to connect to the harbor network. For my harbor it is up and running and it works great. However, I haven't been able to figure out how to program multiple WiFi interfaces in WinBox. Basically, I'm looking to create a list of networks that the Groove will automatically connect to when I'm in range. For example, my home harbor, local restaurant, another harbor, or any other places I visit frequently. Any suggestions on how to do this?
I am also interested to learn how to. Currently I have it done manually but the problems I need to log in via winbox
​​​​​​​Any solutions to this? Would love for the system to automatically connect to networks without having to use winbox.
This device uses legacy wireless radio ?
Then connect list can be used to determine which SSID it is allowed to connect to.
One-time setup. List will be traversed from top to bottom and on first hit it will try to connect.
That's exactly what I'm trying to accomplish. Creating the connect list is what I haven't been able to figure out. I'm probably missing something obvious but this is my first time setting something like this up so I'm a bit lost.
Does this maybe help ?
