Multiple Wireless WAN connections to same ISP
Hi! I’m currently in a situation where the only connection I have to the Internet is via Wi-Fi. The provider in this case limits bandwidth per connected device and I have no control over their implementation. In my current setup, I’ve taken the hAP ax2 units and am using 1 as the router with the 5G radio being used as the connection to the provider (the other radio is disabled), and the second ax2 is acting as an AP for my gear. This all works great, except for the bandwidth limitation. I’d like to use the 2G radio to establish another connection and load balance across the connections. In this case, both connections will have the same gateway on the other side, so I’m having trouble figuring out how to do this well. I’m not concerned about failover. I just want to be able to make use of the bandwidth from the second connection. Any thoughts on how to make this happen? I’ve searched the forums extensively and looked at MUM talks, but haven’t found something that I feel works for my situation. So I’m asking here in hopes of reaching someone who may have more insight into how to accomplish this. Thank you!
