Hello everyone,
I would like to ask if its possible to connect Disc 5 lite (main) with another one Disc 5 lite and after that connect the main Disc to a Omnitik. Distance between the main and secondary Disc is around 2.5km and is in clear sight. The Distance from the main to the Omnitik is around 3km. Secondary and Omnitik are 1km apart.
So the main i guess would have to act as multipoint connection ?
Put directly the secondary to the omnitik, otherwise is really a bad idea.
So the main reason of doing this is cause there is no way to connect secondary Disc to the Omnitik ( Buildings and forest ) in the path , hence the need for the main.
If this setup is not suitable what would you recommend ?
omni (ap-bridge) ->wireless-> disc5a (station-bridge) ->cable-> disc5b (bridge) ->wireless-> disc5c (station-bridge)
Thank you for the reply ,
How bad would be to stick to two Disc5 and Omnitik setup.
Also would be better if i put on the place of the main which is connected to both omnitik and secondary , a SXTG-5HPnD which could act as WISP AP?
Ignoring the bad signals, because Disc5lite is studied for PTP link between AP and Station,
you must purchase a level 4 license for the Disc5 on the middle, this do not value the effort…
Put directly another Disc5 lite…
The same if SXTG-5HPnD have Level 3 license.
If the SXTG-5HPnD have level4 license, you must configure it as “repeater”, not literally or you cause interferences on other clients connected to omnitik.
Another soluction is: put omnitik on the middle…
But if you have omitted (and is what I think) that omnitik act as AP for more client…
This is the map. Currently we have Omnitik installed in this position while the main and secondary need to be conected somehow to the internet.
Because the secondary cant be connected to the Omnitik and there is need to have a router on the main site it looked the most logically thing to do.
Understanded, you use omnitik as router because has 5 ports.
The options available are on table, is your choice now.
