MUM Europe 2017: new hardware incoming!
Great lineup! I’d like to hear about release dates and prices.
No prices have been announced. The release dates for all devices are Q2/Q3 2017, approximately.
Where will be the new RB1100Ahx4 in terms of packet proccessing power? Is it behind or ahead of CCR1009?
well the slides do give you some idea:
5.5 million PPS
7.5Gbps
IPsec up to 2.2Gbps with AES128
Overclock up to 2GHz
How much load will be possible with this UPS-Device?
So simple attach a 12V Car battery which gets loaded with this device and used when power is gone?
I don’t think it can handle car battery, you would be talking about small 7AH battery max. To charge car battery you will need around 10A charging current, you will burn cat5 cable if you will try to send such current over poe.
what Is planned date of availability for 60ghz products? what will be price range, and distance for LHG 60GHz? in slide it says over 100m, in reality, how moch more than 100m. will it reach 1km?
60GHz has a problem with oxygen and humidity. You will not see more than half a mile with acceptable availability. This is with available wifi based 60GHz gear so I guess it will be roughly the same.
We run an ignite link over 850m in Germany, with 1,2 GBit Brutto link and about 800 MBit TCP throughput, It would be Nice to See something simular with LHG,
For a Calculation we Need the Gain of LHG 60G
Mistry7
Does (wAP LTE kit) support Carrier aggregation (CA) (CAT6) ??
This is half a mile :wink:.
RB1100AHx4 no sfp+?
mUPS love the idea but you need extra case for battery!?! extra cabling,12v … cable length limited, mUPS is for outdoor use so why no bigger case just to fit one 7Ah battery…also if u use extra case for battery it must be close to mUPS (max 3m /12V) and be really careful where battery case is mounted, not to be exposed to sun light.
mUPS should look something like Tesla PoweWall - 24V battery connector and bigger case to fit 2 small (7.5Ah) battery - input should be 24-40V so you can also attach solar panel as alternative.
I expected more; wsAC lite, ltAP. LtAPmini, hap mini, wap LTE Kit,bla bla mini these are just a bunch of wifi routers, power box->hex poe, 8 and 24 PoE out switch - these are offered by tp-link and ubnt 2 years ago. Sorry for my sarcasm.
wAP 60G 100m - like it if its very cheep…
LHG 60G - no details ?!? It’s 60GHz up to 1.5km…Ok I m going to shut my mount…
and finally no Multi‑User MIMO?ah Mikrotik?!?!?!??!?
anything about passive optical network ??? why mikrotik?? why???
