must select network
HI,
I have got this messages in logs while connecting to BS:
13:39:24 wireless,debug wlan1: must select network
13:39:24 wireless,debug 00:0E:8E:23:2B:D6: on 5320 AP: yes SSID WLAN_xxxx caps 0x411 rates 0x3f00 basic 0x100 MT: yes
13:39:24 wireless,debug 00:0C:42:23:82:D4: on 5700 AP: yes SSID Wieraaa caps 0x421 rates 0x3c00 basic 0x3c00 MT: yes
13:39:24 wireless,debug 02:02:6F:23:87:70: on 5700 AP: yes SSID poliny caps 0x431 rates 0x3c00 basic 0x3c00 MT: yes
13:39:24 wireless,debug wlan1: 00:0E:8E:23:2B:D6 does not use Nstreme, skip
13:39:25 wireless,info 02:02:6F:23:87:70@wlan1 established connection on 5700, SSID polin
Why the CPE is trying to connect to others BS. This SSIDs are not in connect list? Only “polin” is in connect list.
regards
TopLek
regards
TopLek
most likely you had empty ssid in the wireless interface and the client reported that it can’t select that network because it uses nstreme.
No the SSID is not empty, also SSID in connect list is not empty
In result the CPE is connected to poli SSID, but why before that client is trying to connect to others APs.
HI,
Maybe one of the MikroTik team known the solution???
reg.
TopLek
