Mutliple IP exclude issue in firewall block rule
Greetings,
I’m trying to block torrent on my network I’m using /23 subnet. Requirement is to exclude certain IPs from /23 reange. So far I see only to exclude one ip at a time. How do I exclude around 20 IPs.
I.E 172.16.144.30 , 172.16.144.55 ,172.16.144.85 , 172.16.145.20 , 172.16.145.30 , 172.16.145.56 . Here is my rule
/ip firewall layer7-protocol
add comment="Block Bit Torrent" name=layer7-bittorrent-exp regexp="^(\\x13bitt\
    orrent protocol|azver\\x01\$|get /scrape\\\?info_hash=get /announce\\\?inf\
    o_hash=|get /client/bitcomet/|GET /data\\\?fid=)|d1:ad2:id20:|\\x08'7P\\)[\
    RP]"
add action=add-src-to-address-list address-list=Torrent-Conn \
    address-list-timeout=2m chain=forward layer7-protocol=\
    layer7-bittorrent-exp src-address=172.16.144.0/23 src-address-list=\
    !allow-bit
add action=drop chain=forward dst-port=\
    !0-1024,8291,5900,5800,3389,14147,5222,59905 protocol=tcp \
    src-address-list=Torrent-Conn
    !0-1024,8291,5900,5800,3389,14147,5222,59905 protocol=udp \
Looking forward to your kind response.
Regards
I guess use of address list with allowed IPs is the only way …
well again in address-list I’m allowed to create wither single IP address or range , but in my case I have to exclude some random IPs not in range like 1-10 . It could be 2 , 5 , 20 or 25 , so is there any way to do that.
So I had to add each ip one by one into allowed-bit .
Regards
Yup, the only way is to add a bunch of individual entries to the address list.
That’s the way it works - you add several IPs by one and then have a single address list with multiple single IPs and use it in filter rules.
Or I misunderstood the question ?
All are you guys correct. Since I’m new to Mikrotik and I’m on test phase before moving to production. I’m Linux lover and on Linux there is a plenty of way to achieve it in a single Rule. Yet customization is there . Hope with Mikrotic I will have a good experience as well. It has license while on linux there is no license at all.
Regards
Scorpoin
When you understand IP addressing and subnetting well, you can add multiple IP as a single entry in some cases.
E.g. when you want to add 10.0.0.4 10.0.0.5 10.0.0.6 and 10.0.0.7 all to the same address list you can add 10.0.0.4/30
But when you are really after specifying individual systems for some task, it is probably better to add them as individual addresses.
Note that you already need only 1 rule, that refers to the address list, and the address list then contains all the addresses you want to refer to.
(you can add quite a lot of addresses to a single address list!)
So your firewall rule set remains simple.
