Firewall rules fixed up…
ORDER IS IMPORTANT!!! (within a chain).
First get rid of your raw rules…
/ip firewall raw
add action=drop chain=prerouting comment=“Test block 192.168.1.3” disabled=
yes src-address=192.168.1.3
add action=drop chain=prerouting comment=“Block Zile” disabled=yes
src-address-list=zile
This rule has been removed because its purpose is unknown. Unless its for a service that exists on the MT its misguided…
add action=accept chain=input comment=“defconf: accept LMT provisioning”
dst-port=8081 protocol=tcp src-address=212.93.97.83
EDIT: Okay so this is for some ACS service and you are using TR069 ??? OKay, but I thought it was for Https, as far as I know 8081 is not an HTTPS port ???
I took out the roblox rule there but not sure what it does… or even if the Forward chain is the right spot for this rule. Nothing is going to hit your LAN from port 80 or 443 unless you let it!
add action=drop chain=forward comment=“block roblox” dst-port=80,443
layer7-protocol=Roblox protocol=tcp
ip firewall filter
“defconf: accept established,related,untracked” connection-state=
add action=drop chain=input comment=“defconf: drop invalid” connection-state=
invalid
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
“defconf: accept to local loopback (for CAPsMAN)” dst-address=127.0.0.1
add action=drop chain=input comment=“defconf: drop all not coming from LAN”
in-interface-list=!LAN
add action=accept chain=forward comment=“defconf: accept in ipsec policy”
ipsec-policy=in,ipsec
add action=accept chain=forward comment=“defconf: accept out ipsec policy”
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack”
connection-state=established,related disabled=yes hw-offload=yes
“defconf: accept established,related, untracked” connection-state=
add action=drop chain=forward comment=“defconf: drop invalid”
connection-state=invalid
add action=accept chain=forward in-interface-list=LAN out-interface-list=WAN comment=“allow internet traffic” { added rule }
add action=accept chain=forward connection-nat-state=dstnat comment=“allow port forwarding” { modified }
add action=drop chain=forward comment=“drop all else” { added rule }
THEN test your traffic and report back.
Now to block 192.168.1.3 from the internet simply do this!!! Which amounts to blocking specific user(s) access JUST BEFORE allowing everyone else access to the internet!!
add action=drop chain=forward scr-address=192.168.1.3 out-interface-list=WAN comment=“drop userX from internet access”
If you have a number of IPs that you wish to prevent accessing the internet then make up a firewall address list call it NoInternet
Then the rule would be
add action=drop chain=forward scr-address-list=NoInternet out-interface-list=WAN comment="drop userX from internet access
