Hey i have sett up my first mikrotik ap, but i got a ping problem.
And i do not now what is a good signal and a bad singal.
All this things is new for me.
Will try to give you all the info that i now about so u mabe can help me.
Its 2.17 km bettwen the client and AP
AP Hardware:
Routerboard 532A
Super Range 5 400mW 802.11a 5.8GHz
Gigasector1690 antenna Gain 16 dBi Frequency 5,450 - 5,750 GHz
Client Hardware:
Routerboard 133C
GigaEter18 antenna Gain 18 dBi Frequency 5150-5850 MHz
Ap config:
name=“wlan1” mtu=1500 mac-address=00:15:6D:53:7F:F7 arp=enabled
disable-running-check=no interface-type=Atheros AR5213
radio-name=“GGnet_fjell” mode=ap-bridge ssid=“ggnetfjell” area=“”
frequency-mode=manual-txpower country=no_country_set antenna-gain=0
frequency=5745 band=5ghz scan-list=default rate-set=default
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,
54Mbps
basic-rates-a/g=6Mbps max-station-count=2007 ack-timeout=dynamic
tx-power-mode=default noise-floor-threshold=default
periodic-calibration=default periodic-calibration-interval=60
burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=dynamic
wds-default-bridge=bridge1 wds-default-cost=100 wds-cost-range=50-150
wds-ignore-ssid=no update-stats-interval=disabled
default-authentication=no default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 proprietary-extensions=post-2.9.25
hide-ssid=yes security-profile=default disconnect-timeout=3s
on-fail-retry-time=100ms preamble-mode=both compression=no
allow-sharedkey=no
Client config:
54Mbps
allow-sharedkey=no
Signal info AP to client:
Signal strenge: 73-76 dBm
Tx Signal strege: 74-78 dBm
Signal to noise: 21 dB
Ping:
2-5 ms normaly
but go up to 30-100 ms random just for 1 one ping and its go down agen.
2-9 times in minuts
and when i take a bandwidth test its just goes to 12 Mbsp and the ping will be up to 30-50 ms and the ping will stey so high and drops som pings. so realy unstable.
Have try to change freq but the ping will not be good, have fonde one freq where i can get up to 20 mbps but the pings stey bad and more i use the bandwhidt. ping just get hight and higher.
