Hello everyone…
It’s my first mikrotik (hAP ax3) and I’m a little saturated with so much information.
I would like to know what I need to add or what I should change…
Wireguard
I can ping from the router to the mobile and from the mobile to the router
I can scan the network from my mobile with Network Analyzer
I can’t ping from PC to mobile
I want Wireguard to have access to the LiteBeam 5AC Gen2 antennas…but I don’t want the antennas to have an Internet connection…only LAN…is it possible?
I would also like help with the Firewall…because there are many places to download rules but I don’t trust it very much and I prefer to ask here
Greetings and thank you very much.
This is my net
ISP router in mode ONT — hAP ax3 — LiteBeam 5AC Gen2 → LiteBeam 5AC Gen2 — LiteBeam 5AC Gen2 → LiteBeam 5AC Gen2 — 2x Redmi Router AC2100 (OpenWRT)
— ethernet conection
→ wifi conection
LiteBeam 5AC Gen2 are in mode Bridge
Redmi Router AC2100 are in mode dumb AP
# 2024-03-13 08:19:59 by RouterOS 7.14
# software id = XEMU-N0CS
# model = C53UiG+5HPaxD2HPaxD
# serial number =
# Backup
# 00_identity_services_NTP.rsc
/ip service
set api disabled=yes
set api-ssl disabled=yes
set ftp address=192.168.1.0/24 disabled=yes port=**
set ssh address=192.168.1.0/24 port=**
set telnet address=192.168.1.0/24 disabled=yes port=**
set winbox address=192.168.1.0/24 port=**
set www address=192.168.1.0/24 port=**
set www-ssl disabled=yes
/system clock
set time-zone-name=Europe/Madrid
/system identity
set name=Casa_Router
/system note
set show-at-login=no
/system ntp server
set broadcast=yes broadcast-addresses=192.168.1.255 enabled=yes
# Backup
# 01_Internet_Jazztel.rsc
add comment="Bridge LAN" name=bridge_lan
add bridge=bridge_lan comment="Ports LAN" interface=ether2
add bridge=bridge_lan interface=ether3
add bridge=bridge_lan interface=ether4
add bridge=bridge_lan interface=ether5
add bridge=bridge_lan interface=wifi1
add bridge=bridge_lan interface=wifi2
set [ find default-name=ether1 ] comment="Red WAN" name=ether1_wan
set [ find default-name=ether2 ] comment="Red LAN"
add name=WAN
add name=LAN
add comment="Interface List WAN" interface=ether1_wan list=WAN
add comment="Interface List LAN" interface=bridge_lan list=LAN
/interface vlan
add comment="VLAN Internet" interface=ether1_wan name=Internet_Jazztel vlan-id=1074
add address=192.168.1.1/24 comment="Address LAN" interface=bridge_lan network=192.168.1.0
/ip dhcp-client
add comment="DHCP Client Jazztel" interface=Internet_Jazztel use-peer-dns=no
set allow-remote-requests=yes cache-size=4096KiB servers=1.1.1.1,8.8.8.8
add comment="Pool Casa" name=dhcp_casa_pool0 ranges=192.168.1.240-192.168.1.254
add address-pool=dhcp_casa_pool0 comment="DHCP Server Casa" interface=bridge_lan name=dhcp_casa
add address=192.168.1.0/24 comment="Networks Casa" dns-server=192.168.1.1 gateway=192.168.1.1
/ip dhcp-server lease
add address=192.168.1.12 comment="Leases Casa" lease-time=1d mac-address=00:1E:5F:2F:B9:93 server=dhcp_casa
add address=192.168.1.92 comment="Leases Mateo" lease-time=1d mac-address=00:1E:B1:2C:B1:87 server=dhcp_casa
add address=192.168.1.111 comment="Leases Campo" lease-time=1d mac-address=00:1E:27:48:59:0E server=dhcp_casa
add action=accept chain=input comment="Filter Rules permitir ICMP" protocol=icmp
add action=accept chain=forward comment="Filter Rules permitir established and related connections" connection-state=established,related
add action=drop chain=input comment="Filter Rules denegar invalid connections" in-interface-list=WAN
add action=masquerade chain=srcnat comment="NAT Internet" out-interface=Internet_Jazztel
set discover-interface-list=static
# Backup
# 02_Wifi.rsc
/interface wifi channel
add band=2ghz-n comment="Channel WIFI" disabled=no frequency=2412-2472 name=Casa2 skip-dfs-channels=disabled width=20/40mhz
add band=5ghz-ac disabled=no frequency=5180-5825 name=Casa5 skip-dfs-channels=disabled width=20/40/80mhz
/interface wifi security
add comment="Security WIFI" disabled=no name=Casa
/interface wifi configuration
add channel=Casa2 comment="Configuracion WIFI" disabled=no mode=ap name=Casa2 security=Casa ssid=Casa
add channel=Casa5 disabled=no mode=ap name=Casa5 security=Casa ssid=Casa
/interface wifi
set [ find default-name=wifi2 ] channel=Casa2 channel.frequency=2412-2472 comment="Red WIFI" configuration=Casa2 configuration.mode=ap disabled=no name=Casa2 security=Casa
set [ find default-name=wifi1 ] channel=Casa5 configuration=Casa5 configuration.mode=ap disabled=no name=Casa5 security=Casa
# Backup
# 03_redireccionar_IPs.rsc
/routing table
add fib name=sin_internet
add blackhole comment="Route List sin internet" disabled=no distance=1 dst-address=0.0.0.0/0 gateway="" pref-src="" routing-table=sin_internet scope=30 suppress-hw-offload=no target-scope=10
/ip firewall address-list
add address=192.168.1.5 comment="Address Lists Antenas" list=ips_redireccionadas
add address=192.168.1.6 list=ips_redireccionadas
add address=192.168.1.7 list=ips_redireccionadas
add address=192.168.1.8 list=ips_redireccionadas
add address=192.168.1.90 list=ips_redireccionadas
add address=192.168.1.100 list=ips_redireccionadas
add address=192.168.1.12 comment="Address Lists SAT" disabled=yes list=ips_redireccionadas
add address=192.168.1.92 disabled=yes list=ips_redireccionadas
add address=192.168.1.111 disabled=yes list=ips_redireccionadas
add address=192.168.1.13 comment="Address Lists Casa TV" list=ips_redireccionadas
add address=192.168.1.14 list=ips_redireccionadas
add address=192.168.1.105 comment="Address Lists Campo Router OpenWRT" list=ips_redireccionadas
/ip firewall mangle
add action=mark-routing chain=prerouting comment="Mangle IPs redireccionadas" new-routing-mark=sin_internet passthrough=yes src-address-list=ips_redireccionadas
/ip cloud
set ddns-enabled=yes ddns-update-interval=1m
add action=accept chain=input comment="Filter Rules permitir Mikrotik desde Internet" dst-port=** protocol=tcp
add action=dst-nat chain=dstnat comment="NAT eMule" dst-port=48000 protocol=tcp to-addresses=192.168.1.10 to-ports=48000
add action=dst-nat chain=dstnat dst-port=48001 protocol=udp to-addresses=192.168.1.10 to-ports=48001
add action=dst-nat chain=dstnat comment="NAT qBitorrent" dst-port=48002 protocol=tcp to-addresses=192.168.1.10 to-ports=48002
# Backup
# 04_Wireguard.rsc
/interface wireguard
add comment="Wireguard Casa" listen-port=13231 mtu=1420 name=wireguard_casa
/interface wireguard peers
add allowed-address=192.168.10.15/32 comment="Peer Movil" interface=wireguard_casa public-key="**"
add action=accept chain=input comment="Filter Rules permitir WireGuard UDP" dst-port=13231 protocol=udp
add action=accept chain=forward comment="Filter Rules permitir WireGuard to LAN" in-interface=wireguard_casa out-interface-list=LAN
add action=accept chain=forward comment="Filter Rules permitir LAN to WireGuard" in-interface-list=LAN out-interface=wireguard_casa
add address=192.168.10.1/24 comment="Address Wireguard" interface=wireguard_casa network=192.168.10.0
# Backup
# 05_Pi-hole.rsc
/interface veth
add address=192.168.1.2/24 comment="VETH Dockers" gateway=192.168.1.1 name=pi-hole
add bridge=bridge_lan comment="Ports Pi-hole" interface=pi-hole
add action=masquerade chain=srcnat comment="NAT Pi-hole" src-address=192.168.1.0/24
/container envs
add comment="Envs Pi-hole" key=TZ name=pihole_envs value=Europe/Madrid
add key=WEBPASSWORD name=pihole_envs value=**
add key=DNSMASQ_USER name=pihole_envs value=**
/container mounts
add comment="Mounts Pi-hole" dst=/etc/dnsmasq.d name=dnsmasq_pihole src=/usb1/etc-dnsmasq.d
add dst=/etc/pihole name=etc_pihole src=/usb1/etc
/container config
set registry-url=https://registry-1.docker.io tmpdir=usb1/pull
/container
add comment="Container Pi-hole" envlist=pihole_envs interface=pi-hole logging=yes mounts=etc_pihole,dnsmasq_pihole root-dir=usb1/pihole start-on-boot=yes
# Despues de iniciar Pi-hole
set allow-remote-requests=yes cache-size=4096KiB servers=192.168.1.2
