I have been pulling my hair out of this one. There is a game called Smite I used to play about 6 months back. About that time I got a RouterBOARD 2011UiAS. Since then I couldn’t play the game at all, but everything else was working. At the time I thought it was a bug with Smite as it was still in beta. Since the game was “ok” I didn’t really bother with it.
Take 6 months down the line and I had just installed pfSense at a customer’s location and on a whim I try the game again. After patching it works. Confused I used a crap backup linksys router and it still works. I use a rb750 I carry around with me and it doesn’t work. So now I am confused.
For the sake of argument, lets asume its the router. I have done the whole reinstall of the game and support’s answer was “use another router”. Even if I don’t play the game again, its driving me crazy on why a default installation of pfSense or a linksys works fine, but a very basic RouterOS settings blocks it.
Here is the Firewall filter and ip setup, as I said, basic.
I would suggest not to troubleshoot a game in general but rather to troubleshoot the way game communicates.
So, here are the steps I would take:
Read the manual of the game to see what are its network requirements.
Run Wireshark or similar software and determine what’s the difference in traffic when your game works and when it doesn’t.
Determine what is the difference and then look how you can make it happen with RouterOS.
I do have one wild guess though - it may be related to UPNP. So try turning it on and disabling all your forwarding rules (Mikrotik’s implementation of UPNP will do the NAT forwarding but won’t open that port in the firewall). If this works, then I can post a script that will open UPNP ports in the firewall (or there may be one somewhere already).
I do not know the game, but are there any connections setup from outside.
If so, create a NAT rule and an allowance rule in firewall filter.
Could be that the ‘cheap’ linksys is using uPnP, which makes it more plausible to work out of the box.
Hair extensions and hairpieces really can help to improve the looking of people and help to change them a lot hair extensions and hairpieces if choosing the right type and right style of hair wigs for you, of course that you will look and become more and more attractive and also buy cheap hair wigs now is easy as you can just get the ideal style that you want online at online shops now. I have just buy me a white wigs and it is perfect.
