My hotspot and wireless c;ients are too slow.
Sirs,
I have just installed a Mikrotik wireless client package RB 532 with two 15dBi omni-antenna and two 400 mw mini PCI card for the two antenna. This is to serve as a base station.
I have confiqured the hotspot but I am having the following problems:
  • All my clients receive a very good signal infact excellent signal
    But the browsing speed is too slow compare to my Local Lan which I want to be the same
    Please help this is uregent I am a new ISP, is there a problem in the hotspot confiquration or my wireless interface.
Without looking at your detailed config, I’ll venture a high level of desense between the two omnis; they won’t play together on the same band.
lower the power
*you may use omnis with different polarisation
*try to change frequency to more different channels
regards,
C. G.
