wireless-cm2 is work fine, but can not connect to the wireless-rep package. Both configurations are the same.
Other device connect is fine.
Please upgrade to the latest RC version and check again.
Also check if there is newer intel driver.
If you still have problems make a support output file and send it to support@mikrotik.com
