My Iphone can't get a TX rate better 65Mbps on hAP routers.
I’m a IT staff in a company, and my job’s test the new products before my company buy and re-sell them. I have a new hAP routers and made a little test with it.
I have config my wireless with the option like this:
  • Bandwidth: 20MHz
  • Mode: N only
  • Channel 11 (it’s the best choice when test with inSSIDer)
  • Sercurity with WPA2 +AES.
  • Others are default.
After that i test with my laptop, my Iphone 5s with SpeedTest Software. And have a result:
1/ My laptop get down/up are 50Mbps/50Mbps (My internet line’s only that).
2/ My Iphone only get down/up are 30Mbps/30Mbps. (My phone can get 50Mbps/50Mbps on other WiFi)
I check in info tab of registried device and see my iphone can’t get over 75Mbps/75Mbps when my laptop is 130Mbps/130Mbps.
I don’t know why!? I have test many wireless router with this option, I’ve only get the same bad or good result on both my laptop and my iphone before. It’s the first time I see that.
I don’t think this is because noise or distance. Because I have research before test, and tried come far and near the router.
Does anyone know something? Please help me. Thank you so much.
It could be that iphone doesn’t have 2 chains for the wifi. Laptops usually have 2 chains for the wifi. Apple products usually support only 20mhz channel width for 2.4ghz. For 5ghz they support 20/40mhz channel width where you could higher data-rates.
Thank for your reply. I dont think this isn’t the problem with anten (or chains) on Iphone because I have test with other wifi router (only have 1 or 2 anten on them, eg: Vigor AP, Ubiquiti, LinkSys, TP-Link, ToToLink,…) before, but the Iphone still get more than down/up rate over 30Mbps/30Mbps, don’t like on the hAP.
So I guess this happen because hAP see my iphone only support 75Mbps/75Mbps rate, I will borrow more device to test. It’s very mysterious, I realy want to know how this can happen.
PS: I’m using RouterOS v 6.29.1.
:laughing:
try to setup a 20/40Mhz channel, set the rts/cts, distance to indoor, enable the Wireless-fp package.
Update to 6.28 with last firmware
and check again
Thank you for your answer. I have used the options like you said but it’s result is worse than 20MHz (I think it’s because noise of others wifi).
I don’t see wireless-fp option on my router, and after a little search I think it’s wireless-cm2, is it right? If that’s it, I have this packet is enabled.
I’m using an RouterOS v6.29.1 with all lasted packages too.
I have checked againt with a longer time and see something fun:
1/ My laptop’s Tx/Rx rate will drop to 65Mbps too (Winbox show 65Mbps 20/1S), it’s happen randomly, even when I sit next to the router hAP.
2/ My Iphone’s have support HT20-7 in signal tab, and I remember with this I have got a real down/up rate over 45Mbps on other router.
3/ The max rate of mobile devices is 65Mbps-20MHz/1S (not 72Mbps on the 1st post, very sorry about this mistake).
So in the end, I guess hAP using inner-anten so the Tx signal’s not good enough when send data mobile devices (I test with an other Kindle HD too). Or this is a bug of software made anys have “power save” wireless option can’t over 65Mbps/20/1S. Don’t know what is happening here. :smiley:
If someone know anything else, please tell me know. Thank you so much.
PS: This’s the first time I meet a device what I can vote it’s good or bad. But by anyway, I love the funtions of winbox, I can know exactly what happen in the router.
Surely it is not a problem of hap design. I have devices with steady 300/300 connection rate to hap lite. You have either misconfigured your devices or interference or too strong signal.
Thank you for your reply.
I don’t sure my config is wrong or right. All I made are change the chanel to 11 (recommented by inSSIDer), Bandwidth to 20MHz, mode to “N only”, sercurity use WAP2/AES.
After that I connected my devices and speed test. I’m only see what is happening via WinBox tool.
My testing devices is tested againt on other router and I don’t see any problem.
If you know what need to change, please tell me.
PS: My Iphone is 5s and use iOS 8.1 buy form USA Verizon. My laptop is Dell Inspiron 15z using Windows 8.1 updated all fix with wireless card Intel Centrino Wireless N 2230 (driver version 15.10.3.2 date 8/22/2013). RouterBoard hAP use OS 6.29.1 ID routerboard 941-2nD.
Don’t rely on ssider only. Use spectral scan in addition, you can see things… . Use 20/40 mode too. Also take care not to have too strong signal (minus50-60db) and to have good signal to noise ratio (at least 40db). I don’t use iThings at all, but they are widely discussed as not always fully following the wifi standards.
I have tried 20/40 mode before, but the result isn’t good. The bandwidth show in Winbox tool are: my laptop is 300 Mbps/300Mbps, but my iPhone is still 65Mbps/65Mbps. And the real bandwidth when test with speedtest and download from server is not over 30Mbps on my iPhone. Some time you will get slower bandwidth than using 20MHz (I think it because the conflicted with other WiFi).
And maybe I wrong but as I know, when you want a good signal of wifi, you need:
1/ The noise of other wifi is slow (from -60 to -99).
2/ And the good signal of your wifi (from -20 to -50).
If I’m wrong, please tell me. I really want know more about it.
PS: I’m using the hAP for an apartment of my friend, and will see what are they think aboult it. :slight_smile:
Good noise is below minus 110. 60 is definitely very bad noise. Use spectral scan to see what frequency is the best for you.
The signal should be between -50 and -70 for decent speeds.
Any hotter than that and you’ll have issues.
I don’t get it.
Your phone is single chain and 20Mhz, so maximum conection rate is 65mbps. What is the problem?
Thank all of you for the support and information.
This is the first time I knew about Spectral tool of Mikrotik, I will learning the way to use it. Thank you for your information.
I don’t really understand your mean? Is it’s mean, the too strong signal will made the worse result when speed test? Many thank if you could say it clearly.Or could you show me where to read about it, plz?
Maybe I made you misstake.
My problem is the iphone can’t download over 30Mbps (real bandwidth) on hAP, don’t like when I use an other WiFi (eg:Vigor AP 810). And my laptop can get the full bandwidth 300/300Mbps on hAP.
So I don’t know it’s my fault to wrong config on hAP or any thing else.
When connection rate is 65mbps, real data speed is half. So 30mbps is almost half of that.It is weaker than Vigor? I don’t understand what “don’t like when I use an other WiFi” . Don’t use it if you don’t like it.
Too strong signal is as bad as too weak signal. Can you enjoy all details in the music when it is too loud?
A very interesting and easy to understand sample.
Could you tell me it’s apply to all device,it isn’t? Because I have some Alcon APE and outdoor AP of Ubiquiti with very high Tx power and very high dpi anten. Then if I get near them I will get worse speed rate than far of them?
So I will get the good speed rate when:
1/ The noise is smaller than -90.
2/ The signal is not too high, only between -50 to -60.
Is it right?
And if I have my wifi is channel 1, but have a high noise from channel 6/11, is it still OK?
Thank you so much for your help.
I’m very sorry, but I never said anything to complain hAP. Because I alway get a same bad or good result on my laptop and my phone, so when see not the same result on hAP, I’m only want know why?
I know maybe I have wrong config somewhere, so I tried to asked someone could show me that. And if you think it only because my phone then it’s ok too. Thank you about that.
You got it.
You can try to enable short guard inteval to get 72.2Mbits instead 65Mbits data rate if it is supported by your iphone.
You can enable 20/40HT to get 150Mbits with short guard interval, when supported by your iphone.
These are the maximal physical throughputs with 802.11n using single chain. As your iphone surely does not have 2x2 mimo radio, you cannot have more than that.
I also saw links working with -25dbi signal. But it is useless, consuming too much electricity, heat and making much bigger unnecessary noise for others. Problem is that those too hot links do not normally reach high modulation rates with perfect ccq.
Everything has to be tuned on its place, but around the “normal” values and with respect to law regulation and to others. None is alone in the air.
Everytime use as low power as possible that yet ensures quality link for you. If you would need to go too high, think about it again and make some other action (more directional antennas, more sensitive radios, better pigtails, technology / band change). Better to be in advance before others than just turning the power knob to the right side.
Thank for your information.
I will test with them after I got hAP from my friend.
Thank for show me many new options to have a good wifi signal.
So the best way is enhance reception quality, not simple’s increase the Tx power what will make more nosie to other wifi.
And I have one more question. If I use WDS or Repeater to increase the range of wifi’s signal, the noise of sub-AP affect the main-AP or not? I always wonder about that, because I see them use the same channel.
yes
repeater generate more contention on channel because it uses the same channel, collisions increase and throughput decrease at half of worst
