my metal 2SHPn 's wireless is always down
In my local network , this device is an ap(a simple wireless AP). When it work, sometimes the ssid is not appered in the area. and that PC are linking to it is down. but this device is working , winbox is login in. In the interface , the wireless 's status is “s”, not"RS", when I reboot it ,it works fine. i upgrade it to 6.20. the problem is not solved.
There is an existing topic about this. Search in the forum.
Also there is a test firmware which fixes this problem for most people.
Here is the test firmware, that should help with most Metal 2 issues: http://www.mikrotik.com/download/share/ar7240_3_19.fwf
To install, upload this file, then do “/system RouterBOARD upgrade”
Please let us know if it helps
I have already download the file, and install, 3.17 upgrade to 3.19
Ok! thks
After the upgrade through the use of a few days, the problem is solved. Thank you very much!
My RB751G device also have this problem, current firmware is 3.09 . Can use this file to upgrade ?
No, there is for rb751G http://routerboard.com/RB751G-2HnD
In 2017, I was one of those who had the same problem. I bought this device a few months ago and got the same problem. May I get the same update? Because I have tried to search everywhere but not found. Hopefully with the update can help solve this problem.
thank you.
