Hi, after upgrading my haplite smips from 6.40 to 6.41rc34 i can’t login with winbox, i can’t see microtok in winbox, i reseted some times and not fiz the problem, please Help me!
do a netinstall
yes I just did for netinstall and it worked, but when importing my configuration file I was giving error in the lines that contained this config:
/ ethernet interface
set [find default-name = ether2] name = ether2-master
set [find default-name = ether3] master-port = ether2-master * error here after master
set [find default-name = ether4] master-port = ether2-master * error here after master
I deleted the part of the master ahead of ether 3 and 4 and I managed to import the settings but now the internet does not pick up on these doors could someone help me?
do a netinstall
I believe it is a very simple mistake to correct but as I started working with microtik now I am really lost
Just ignore the repeat netinstall person.
You need to read this thread and understand it and then act on it.
There are no master ports any more with 6.41, which is why you get the errors.
Also, this on the Wiki:
https://wiki.mikrotik.com/wiki/Manual:Switch_Chip_Features
i understand, but now how i fix this problem in my configs?
i fix then importing line per line of configs and excluded ethernet configurations!
Thanks for atention!
Presumably you need to add ether3 and ether4 to the same bridge as ether2.
It might help if you posted the relevant part of the config. - “/interface export hide-sensitive”
6.41rc dont support master-port. They implemented new bridge (no more mastrer-port) so when you trying import old config it gives error
Wysłane z mojego GT-I9505 przy użyciu Tapatalka
