My Mikrotik RB450 Can't Manage PPPoE User's Bandwidth. Can Anyone Solve The Issue?
Hello Dear,
I am using RB450 with version 6.28. I have PPPoE user and I have allocated them separate bandwidth like 512k or 1 Mb like this. I am attaching some screen shot for your better acknowledgement. Anyway, now the problem is 1 Mb user are using bandwidth upto 4/5/6/7/8 Mb/s. I am confused and I am unable to handle it. Where I have done the mistake. Can anyone help me to solve the issue?
Thanks in advance.
Kawsar
Just a suggestion to not display confidential info (IP address) next time.
Thanks Bro. I will follow the rules next time In Sa Allah.
After change profile for user to you disconnect user ?
If not you must disconnect user to reconnect and pick up new limit and everything is working.
