My Mikrotik Routerboard is hacked
Hi All
I am new to Mikrotik, so please be easy on me.
I recently got notified by my ISP that my IP has been blacklisted. I checked on Spamhaus website and my IP was indeed listed there because of Mikrotik vulnerability.
After investigating, I found I had old version package on my Mikrotik routerboard, so I upgraded the Routerboard OS to latest, upgraded the firmware, changed the password, disable all the IP services other than winbox, changed winbox port, rebooted the router.
I also changed my APs wifi passwords. I then scanned all my machines but could not find infection.
Even after doing this, my IP was still getting lots of hits on Spamhaus.
I started further investigation and found that at any given time, I have about 17000 connections under firewall. Most of these connection are made on port 58154 from random IPs. There are other ports too.
When I checked this port on online checker tool, this port was indeed open but under filter rules I don’t see this port being open.
Under logs, I also see denied winbox/dude from random IPs.
Last weekend, I power down the router and hits got to 0 in last 24hours on Spamhaus but this Monday when router was switched back ON, I got 85 hits in last 24hours.
Tonight, I am planning to power down the switch and leave mikrotik ON. If still I keep getting hit on Spamhaus then it will be clear that Mikrotik is still compromised.
Meanwhile, can you please provide any suggestion to fix this issue?
Regards
use search, you will find 50 post with solutions…
Better give the link: https://blog.mikrotik.com/security/
my router update to 6.42.7 and hacked (i not update password)
anybody have solution ?
