My NAT forwarding is working, but I don't know how!
Every guide I see online says I need to put the external IP in General → Dst. Address:
This doesn’t work, and I can only get this working if the external IP is in Src. Address. Not a complaint, I just can’t work out why it is working. Router is default config.
For context:
I want to access a server on my local network from my office network, which is the IP starting 93
dst-address is meant to be the WAN address of your router the server is located behind. I assume the 93. address is the remote location, correct?
specifying a src-address surely adds some layer of security b/c the dst-nat will only happen when the connection is originated from this particular address.
-Chris
Ah right, yes you are correct. The 93 address is the Office WAN IP, so remote in my case. So my current rule is saying: Anything that comes from IP address 93.x.x.x into the network on port 7272, is to be forwarded to 192.160.x.x on port 80.
Thanks for your explanation.
