i am preparing for my new project but i need some answers
i have 3 lines 200+200+200 and iam using
CCR1009-7G-1C-1S+PC to balance and managing, first question,
all the distance of my work arround 8km, iam using mANTBox 19s as Wisp
do you recommend if i use for 3 locations to use ptp
or i use in every location mANTBox 19s and on new location buy a cpe QRT 5AC for example, did the throughput will be the same or i use ptp?
which protocol i use 802.11 or NV2?
iam thinking to use hap ac lite as cpe for houses near to mANTBox 19s does it working good and how long range in km it will work with me?
Where are you located? How much Bandwidth do you want to get over these 20km links?
With Mikrotik it is nearly impossible to get this results at this distance
you need seperated links, and 30dBi dishes, bigger Dishes are better
you need clean Spectrum
Mistry7
soory its 8 km all the area start from the first point tell the last point its small area do you if i use ptp between each mANTBox 19s is better qrt 5ac or mtp i will use qrt 5ac as cpe and saving the difference which one is better and the bandwidth not less than 600mgb
not possible with 3 separated sectors…
You will not be able to push 200MBit real TCP over 8km with Mikrotik
