My r52 mini pci card is showing incorrect info
Hi there sometimes when i access my routerboard using winbox then the wlan interface will show that i am using aan unknown frquency abs also an unknown securitry profile. But if i reboot the the routerboard then it will show correctly. Can this be that the card is faulty or is the signals just getting confused.
what routeros version you have on the board?
check the files directory for an autosupout.rif file.
