My RB 750 Lan-Port5 always is on
hi,
i have a RB750 that’s it’s Lan-Port no.5 is always on .
i did upgrade it’s RouteOS , reset,HardReset but nothing change and it’s always on .
help me what’s the problem ?
is my RB750 out of order ?
If you are not using or do not wish to use port 5, then the easy way is open Winbox, select interface at top, then highlite port 5 and disable it.
For me, winbox is a lot easyer then terminal.
i need my 5 port
is it hardware fault ?
