my rb outo reset confgra every power off
hi. i hv problem wth rb 751 hnd .roter afer power off and back my router showng reset defult and i must press ok
:global ssid;
#| RouterMode:
#| * WAN port is protected by firewall and enabled DHCP client
#| * Wireless interfaces are part of LAN bridge
#| * IP address 192.168.88.1/24 is set on LAN port
#| wlan1 Configuration:
#| mode: ap-bridge;
#| band: 2ghz-b/g/n;
#| ht-chains: 0,1;
#| ht-extension: 20/40mhz-Ce;
#| LAN Configuration:
#| switch group: ether2 (master), ether3, ether4, ether5
#| DHCP Server: enabled;
#| DNS: enabled;
#| WAN (gateway) Configuration:
#| gateway: ether1 ;
#| firewall: enabled;
#| NAT: enabled;
:log info Starting_defconf_script_;
:global action;
Apply configuration.
these commands are executed after installation or configuration reset
:if ($action = "apply") do={
wait for interfaces
:local count 0;
:while ([/interface ethernet find] = "") do={
:if ($count = 30) do={
:log warning "DefConf: Unable to find ethernet interfaces";
/quit;
:delay 1s; :set count ($count +1);
:local count 0;
:while ([/interface wireless print count-only] < 1) do={
:log warning "DefConf: Unable to find wireless interface(s)";
/ip address add address=192.168.88.1/24 interface=ether1 comment="defconf";
/quit
:delay 1s;
/interface wireless {
set wlan1 mode=ap-bridge band=2ghz-b/g/n tx-chains=0,1 rx-chains=0,1
disabled=no wireless-protocol=802.11 distance=indoors
:local wlanMac [/interface wireless get wlan1 mac-address];
:set ssid "MikroTik-$[:pick $wlanMac 9 11]$[:pick $wlanMac 12 14]$[:pick $wlanMac 15 17]"
set wlan1 ssid=$ssid
set wlan1 frequency=auto
set wlan1 channel-width=20/40mhz-Ce ;
/interface ethernet {
set ether2 name=ether2-master;
set ether3 master-port=ether2-master;
set ether4 master-port=ether2-master;
set ether5 master-port=ether2-master;
add name=bridge disabled=no auto-mac=yes protocol-mode=rstp comment=defconf;
:local bMACIsSet 0;
:foreach k in=[/interface find where !(slave=yes || name~"ether1" || name~"bridge")] do={
:log info "k: $k"
:local tmpPortName [/interface get $k name];
:log info "port: $tmpPortName"
:if ($bMACIsSet = 0) do={
:if ([/interface get $k type] = "ether") do={
/interface bridge set "bridge" auto-mac=no admin-mac=[/interface ethernet get $tmpPortName mac-address];
:set bMACIsSet 1;
add bridge=bridge interface=$tmpPortName comment=defconf;
/ip address add address=192.168.88.1/24 interface=bridge comment="defconf";
/ip pool add name="default-dhcp" ranges=192.168.88.10-192.168.88.254;
add name=defconf address-pool="default-dhcp" interface=bridge lease-time=10m disabled=no;
add address=192.168.88.0/24 gateway=192.168.88.1 comment="defconf";
/ip dns {
set allow-remote-requests=yes
static add name=router address=192.168.88.1
/ip dhcp-client add interface=ether1 disabled=no comment="defconf";
/ip firewall nat add chain=srcnat out-interface=ether1 action=masquerade comment="defconf: masquerade"
/ip firewall {
filter add chain=input action=accept protocol=icmp comment="defconf: accept ICMP"
filter add chain=input action=accept connection-state=established,related comment="defconf: accept established,related"
filter add chain=input action=drop in-interface=ether1 comment="defconf: drop all from WAN"
filter add chain=forward action=fasttrack-connection connection-state=established,related comment="defconf: fasttrack"
filter add chain=forward action=accept connection-state=established,related comment="defconf: accept established,related"
filter add chain=forward action=drop connection-state=invalid comment="defconf: drop invalid"
filter add chain=forward action=drop connection-state=new connection-nat-state=!dstnat in-interface=ether1 comment="defconf: drop all from WAN not DSTNATed"
/ip neighbor discovery set [find name="ether1"] discover=no
/tool mac-server disable [find];
/tool mac-server mac-winbox disable [find];
:foreach k in=[/interface find where !(slave=yes || name~"ether1")] do={
:local tmpName [/interface get $k name];
/tool mac-server add interface=$tmpName disabled=no;
/tool mac-server mac-winbox add interface=$tmpName disabled=no;
Revert configuration.
these commands are executed if user requests to remove default configuration
:if ($action = "revert") do={
remove wan port protection
/ip firewall filter remove [find comment~"defconf"]
/ip firewall nat remove [find comment~"defconf"]
/tool mac-server remove [find interface!=all]
/tool mac-server set [find] disabled=no
/tool mac-server mac-winbox remove [find interface!=all]
/tool mac-server mac-winbox set [find] disabled=no
/ip neighbor discovery set [find ] discover=yes
:local o [/ip dhcp-server network find comment="defconf"]
:if ([:len $o] != 0) do={ /ip dhcp-server network remove $o }
:local o [/ip dhcp-server find name="defconf" !disabled]
:if ([:len $o] != 0) do={ /ip dhcp-server remove $o }
/ip pool {
:local o [find name="default-dhcp" ranges=192.168.88.10-192.168.88.254]
:if ([:len $o] != 0) do={ remove $o }
:local o [/ip dhcp-client find comment="defconf"]
:if ([:len $o] != 0) do={ /ip dhcp-client remove $o }
/ip dns {
set allow-remote-requests=no
:local o [static find name=router address=192.168.88.1]
:if ([:len $o] != 0) do={ static remove $o }
/ip address {
:local o [find comment="defconf"]
:foreach iface in=[/interface ethernet find] do={
/interface ethernet set $iface name=[get $iface default-name]
/interface ethernet set $iface master-port=none
/interface bridge port remove [find comment="defconf"]
/interface bridge remove [find comment="defconf"]
/interface wireless reset-configuration wlan1
:log info Defconf_script_finished;
wow…2016 and still there is no answer?
i facing same problem with rb751u-2hnd
