Site A (Leased Line)<— pptp —>(FTTx; PPPoE) Site B
RB 4011 is at site B. The Traffic usage is only about 200Mbps but it consumes 100% on cpu0 and slow down overall traffic.
I assume that this only happens during high traffic over the pptp connection?
I maintain the idea that this is they way pptp works. The interface will only run over one CPU core and that is the effect you see now. I can be wrong but think this is the way it work. So not a bug but by design.
Still think it is wrong then do a supout file during the issue and send to support with a explanation of the issue.
Hmm, I think RB4011 can do a little more than that, unless you have a funky config.
What MTU did you set for the Wireguard interfaces?
And what MTU do you have on your WAN at BOTH sides (tested)?
I thought so.. My Internet b/w is 1Gbps but can use about 500Mbps with RB4011
I did not set the MTU .. just leave it to default value (1420) for both side on wireguard.
Site A: MikroTik CHR is directed connect to ISP with static IP (Interface MTU is 1500) … cpu only about 10% on b/w 500Mbps
Site B: RB4011 connect Internet with PPPoE and default MTU (1492) … firewall was only 2 rows. and no L7 protocol.
Anyway. I’m satisfied with the current result. 500Mbps is better than 200Mbps as before.
