I have a 2mbit adsl connection. I connect directly to my adsl modem and I reach around 220KBytes in download.
Now I add a RB751G-2HnD connected to the modem.
I have routeros 5.21
I use “quick set” feature to configure it as an access point and I change only wpa password and lan ip.
Now I get only 50KBytes downloads on wireless AND wired internet.
If by speed test you mean a thing like www.speedtest.net I have already done it.
It gives me the same results: 50KB and a somewhat higher ping, 105 ms and not 50/60.
I have done it on wireless and wired.
I have tried also configuring it from scratch without using “quick set” but the result is the same.
I am seeing stats: no loss of packets in any interface. Low ping means that adsl download channel is not saturated.
So it seems that someone is slowing down tcp.
I have solved the problem. I have changed cable without luck.
Then I discovered a lot of crc errors and they were increasing. So I forced 10mbit from rb751 to modem and bingo: all goes nice now.
But I am not satisfied: why I had to force 10mbit? The modem with a notebook or a pc works at 100 mbit.
