My steps to work PPPOE, Is that true?????
and What is your comment on the method of preparation
1-ppp ------>PPPOE Service (+)(service name:service1, Interface:ether2,Keepalive Timeout:10)
2-ip ------>Pool ----->(+)------>Name:pppoe1 ,adress: 192.168.1.20-192.168.1.55
3-ppp----->Profiles------>Nam:prof1,Local Address :192.168.0.1,Remote Address:pppoe1, DNS Server:213.244.72.31&212.14.234.36 , Use Encryption:requierd ,
Change TCP MSS:Yes ,
----->Limts------>Rats Limt:128k/192k , Only One :Yes
4-New PPP Secret----->Name:jon, Pasword:1234,Profile:prof1 look it
http://i299.photobucket.com/albums/mm316/srmed2000/pho.jpg?t=1211179398
Additional Information
Server MikroTik connected by 20 PC,Distribute the InternetSpeed Internet each PC is 128k/256k ,Now; eather1( RouterOS)is 113.112.114.9/30eather2 (geateway) 113.112.114.10/30DNS is :213.244.72.31212.14.234.36
Looks good.
It’s easier if you post your configuration
However you should disable compression and encryption in profile
And for more security remember to remove any IP from ether2
And don’t assign 192.168.0.1 on any interface
Thank you “EgyCom” very much for your reply fast
I did everything they asked me,
I have two questions:::::::::> :question:
Q1-Where find ??? I don’t assign 192.168.0.1 on any interface, When doing in Profiles;Local Address :192.168.0.1,is cut off contact.!!!
Q2-How and Where remove any IP from ether2
Please Give me Setting pppoe typically and security, and I want they ping very low
are you find is excellent
But How:
remove any IP from ether2 ???
don’t assign 192.168.0.1 on any interface ???
i need you to post your configuration so i can help u
i mean don’t assign IP address on ether2
Information
My pc Server MikroTik (v3.9) connected by 25 PC, Distributes Internet through wireless and HUB
DNS is :
213.244.72.31
212.14.234.36
MY seting PPPOE is
3-ppp----->Profiles------>Nam:prof1,Local Address :192.168.0.1,Remote Address:pppoe1, DNS Server:213.244.72.31&212.14.234.36 , Use Encryption:No ,
I need to be an excellent Internet service distribution and security high
DO You want my Bukup file of the Server??To amend it
i don’t want you to write your first post again :frowning:
just in CLI type below and then post output
ip address export
interface pppoe-server server export
ppp profile export
sorry i dont speak english good ,I’m from Italy
ip address export : ehere2 , 113.112.114.9
interface pppoe-server: ether2
ppp profile :Local Address :192.168.0.1,Remote Address:192.168.1.20-192.168.1.55
Please tell me what to do?Even if the fungi to change all the settings!![/
color]
Do you still want to help me
shereer
You have been asked for the configuration.
Open up a terminal/telnet/ssh/prompt/cli and then type:
ip address export
ppp profile export
For example:
[admin@MikroTik] > /ip addr pr
ADDRESS NETWORK BROADCAST INTERFACE
0 ;;; added by setup
113.112.114.9/30 113.112.114.8 113.112.114.11 ether1
1 X 192.168.0.1/24 192.168.0.0 192.168.0.255 ether2
2 D 192.168.0.1/32 192.168.0.228 0.0.0.0
[admin@MikroTik] >
Hello iam8up
is OK ?? :open_mouth:
???Setting pppoe typically and security???
ok
in image 1 , delete 192.168.0.1 from ether2
in image 2 , remove service name (leave it blank)
in image 3 , disable VJ compression
in image 8 (firewall NAT) , delete the first role
Thank you very much
I have only fore questions:::
Q1- about image 1 ,How can I delete 192.168.0.1 from ether2 ???
Q2- What about of the Local adress:192.168.0.1 in image 3 ???
Q3- in image 8 (firewall NAT) , delete all the role Or only the second and third ???
Q4-How can I contact is better than , the quality of the Internet, and low ping???
PLEASE HELP ME !!! :confused:
Mr EgyCom
Please Answer the questions … We have approached that finished the good of the Server ppoe … This is the last thing I am asking you :slight_smile:
about image 1 ,How can I delete 192.168.0.1 from ether2 ??? Becoase is Dinamic IP !!!
[size=150]about image 1 ,How can I delete 192.168.0.1 from ether2 ??? Becoase is Dynamic IP !!![/size]
