My VOIP phone won't use the L2TP tunnel
I’m definitely a newbie - trying to use my RouterBoard RB750r2 after consumer routers (Netgear) is pretty hair raising :slight_smile:
I’m currently behind a 4G NAT router so to make my Snom VOIP work properly I decided to set up a L2TP tunnel to my VOIP ISP who is Andrews & Arnold, using my RouterBoard.
I got a little help and set up the L2TP tunnel and it appears to be established with a (local) IP address I can ping.
In Firewall, I set up a Masquerade, Chain srcnat to the L2TP tunnel, but to no avail, the phone insists on registering and sending data via the normal ether 1 route, not via the L2TP tunnel.
How can I make the phone, (on 192.168.88.253) use the tunnel?
Do I need to change any settings (e.g. Gateway?) on the phone to make this work?
I’m using Winbox to administer the box.
Grateful for any hand holding!
This can be done relatively easily, your problem is that to get to the internet your router is routing through your 4G provider.
You need to add a route the same distance as your default route however give it a routing mark to look for (voip for example).
Next you need to actually mark your packets you want going down the L2TP tunnel using Mangle
add action=mark-connection chain=prerouting in-interface=XXX new-connection-mark=voip passthrough=yes src-address=VOIP.PHONE.IP.HERE
add action=mark-routing chain=prerouting in-interface=XXX new-routing-mark=w3z passthrough=yes src-address=VOIP.PHONE.IP.HERE
Finally, adjust your src-nat rule so it looks for the routing mark as well just for completeness.
Thanks Steve, I assume I should use a New Terminal to do this (I’m using the Winbox interface)?
