Looking for help with my computer’s Winbox using multiple loggins when logging into a unit with Winbox.
It logs in regularly via Winbox with my current IP address then follows the login with ~18 via telnets loggins with the same IP address.
I have attached a picture of the log displaying it.
This happens with all units I log into and is often overloading the CPU of many older MikroTik units and crashing them.
Looking to find the cause and a solution to stop it.
Thanks.
It’s definitely this - if you have autosave session on (which it is by default) and as you go instead of looking for your old terminal window behind all the others, you just open a new, in time you have ~10 open, and it saves that session layout so re-opens them next login via winbox, which they all are counted as ‘telnet’ logins (on v6)
You can use the new ‘Windows’ list at bottom of the winbox menu to see all your open windows, or Session->Close All Windows to start it from scratch. I personally have a few session files saved for my default layout and then turn off ‘auto save on close’ so it resets back to that layout every time I open.
