Looks like MYNETNAME.NET is down. IP Cloud DDNS not working.
Can you take a look?
I was having the same issue but it looks like it’s back up now.
The same here.
same problem here
yes, back up now. Lasted about 1 hour.
yes it was back up and its down again now
Yep same here. Just got an alert.
Same here… Whats going on?
same for me
Ditto, same problem here, I cannot reach my home VPN and cloud domain name is not resolvable.
Mi folyik itt Gyöngyösön?!
Hát a Gyöngyös-patak!
Seems to be stable now
At least for now.
Unfortunately, this was not an isolated incident as the MT cloud appears to lack sufficient redundancy. Whenever possible, we are phasing out the built-in function in favour of Cloudflare DDNS which is highly redundant and locally available through out the world.
I also have never used the Mikrotik DDNS service. Using Dynu.com and have never had a failure in a good five years.
Naturally, it works, and thus why MT should provide Cloudflare ZeroTrust Tunnel! Reliable!, safe! an excellent options package for all routers.
noticed I dropped a few ddns routers, is it down? I have been pushing the router alone for the ddns service and will need to stop if the service is getting terminated.
thanks for necroposting. better continue here: https://forum.mikrotik.com/viewtopic.php?t=213191
