Hello folks,
I have been reading up on the routerOS ‘N-Streme’ protocol but still not quite certain about the intent and/or capabilities.
Can someone confirm if i am correct to assume that n-streme ‘client polling’ is some kind of token management system?
Thanks & regards, Mike.
tully
2
It is simply polling. There is no token – that is a different technology.
John
OK, thanks for the response. And this polling prevents or controls colissions (ie Hidden node issues)?
regards, Mike.
tully
4
Yes, it prevents any hidden node issues.
John
Excellent! Thanks for the advice.
Regards, Mike.
