N with TDMA on MK or UBNT ????
i need to know which is the better solution if we are comparing real tcp throughput on 802.11n
We are using at this time UBNT Rocket but there is possible maximum 55 Mbps TCP half duplex with enabled Airmax.
Is MK better? Which wh equipments are better.
Use 40 or 20 MHz range ?
Does support MK 300 Mbit modulation on RB711 an? Which minippci card to use on AP, if we want use for klient RB 711 ?
300mbps with 5ghz is’not real. need to watch to 40Ghz proffesional equipment.
REAL traffic you could ahieve ~120mbps full duplex, 2x2 offcourse.. but as i have understood learning the forum, there are problems with 11n
300mbps in 5ghz is real. But not with cheap Equipment.
300mbps is both ways aswell, You wont see 300mbit one way in unlicensed or with MT/UBNT
if we are talking about 4x minipci 802.11n cards on X86 based PC, then could be :laughing:
300mbit in one way ->150mbps full duplex. as i was writing i suppose 2x2 MIMO could press out 120~mbps FULL duplex mode (~240mbps in half duplex).
Are we talking about REAL traffic, not what is written in routerOS as statusconnect :smiley:
54mbps
nstream - gives ~3.2-3.3mb/s at real life
interference. Let us say - its cheap, but all what is cheap or free isnot best.
Let us say - If you cannot understand properly what’s going on and how it works, buy something ready to work which is not cheap.
All your statements in the last post are not correct.
