Naming for mipsbe incorrect
If I run upgrade or download ROS 7 from Winbox the wrong naming is used. It looks for routeros-mipsbe-7.0beta4.npk which is not available.
I downloaded it manually from the site and first going to remove the empty file so that upgrading should go well.
Currently running 6.46RC1 on a RB750GR2.
Yes, all package names are changed. Automatic upgrade from v7 will not work currently.
Also, I don’t recommend it anyway. v7 is not nearly ready for use, for regular users should not accidentally upgrade to it.
