nat 1:1
Hi, this is how is configured a RB750:
ip address
4 ...130/28 ...128 ...143 ether5_WAN
5 ..
.131/28 ...128 ...143 ether5_WAN
6 ...140/28 ...128 ..***.143 ether5_WAN
7 192.168.1.10/24 192.168.1.0 192.168.1.255 ether3_LAN
ip firewall nat
1 chain=srcnat action=masquerade out-interface=ether5_WAN
2 chain=srcnat action=src-nat to-addresses=...140 src-address=192.168.1.250
3 chain=dstnat action=dst-nat to-addresses=192.168.1.250 dst-address=
...140
The rule #3 is working well, when i try to connect to the public ip ...140, services on 192.168.1.250 answer correctly, but when i check the outgoing public ip it tells me ...130 instead of the .140, so the #2 rule doesn’t seem to work.
How can i do? is there something wrong in the rule #2? Thanks
it is hard to understand your configuration and your targets
Not sure I am reading it right, but your 1:1 rules need to be above your masq rules in the firewall->Nat
