правило для NAT
chain=dstnat dst-addres=212.212.75.55 protocol=tcp dstport=999 action=dstnat to-address=192.168.1.151 to ports=80
при попытке зайти на порт .. пишет unreplied, типа не соединен, нужно ли ещё какиенить правила прописывать в других цепочках.
ЗЫ Для 192.168.1.151 прописан форвардинг наружу
Может кто знает,буду благодарен.
Mikrotik 2.9
Задача вывести 80 порт наружу.
Well, I can think that your post will probably have something to do with destination NAT. But if you would post in English, you probably would get more help ![]()
Best regards,
Christian Meis
I have no idea what most of that says, but perhaps you need a src-nat rule with the src-ip=your_internal_server and action=masq for the returning traffic from your inside IP address.
It is required to me that it was visible web server outside 80 port
I have rules
NAT
0 chain=srcnat out-interface=Craft src-address=192.168.1.0/24
dst-address =! 192.168.1.0/24 action=masquerade
2 chain=dstnat in-interface=Craft src-address=0.0.0.0/0
dst-address=22.22.22.58 protocol=tcp dst-port=999 action=dst-nat
to-addresses=192.168.1.250 to-ports=80
Filter
3 chain=input action=accept
5 chain=forward in-interface=Local out-interface=Craft
src-address=192.168.1.0/24 dst-address =! 192.168.1.0/24 action=accept
6 chain=forward in-interface=Craft out-interface =! Craft
src-address =! 192.168.1.0/24 dst-address=192.168.1.0/24 action=accept
But in connections writes that a package syn sent and does not work!
What not so?
Russia.Novosibirsk
These rules work if to make nat on internal network interfaces of a server… And here in a local area network it is impossible
All has made.. Thanks for attention works perfectly
