Nat and preservice public ip for a port
I am not very good in the nat, so need som help if its possible.
I have a router with a public IP on interface ether1.
On inside I have two server.
Server 1 Linux server (172.16.1.10) with only need for web port 22 trough NAT. Simple dest nat.
Server 2 Web server (172.16.1.20) I need port 443 from public IP to the server without NAT.
This way server 2 would see the public IP
Base NAT setup:
add action=dst-nat chain=dstnat dst-port=22 protocol=tcp to-addresses=172.16.1.10
You need src-nat and dst-nat rules…
The first one, is used so that the server is src nated using the Public IP you want, and the later to dst-nat all the incoming traffic to that Public IP to the Server…
/ip firewall nat add chain=srcnat src-address=x.y.z.w action=src-nat to-addresses=public_IP
/ip firewall nat add chain=dstnat dst-address=pulic_IP dst-port=443 protocol=tcp  action=dst-nat to-addresses=x.y.z.w
But the problem is you don’t want to use any NAT rules…
And the question is, why you do not want any NAT ?
Jotne, you want to forward public port 443 packets to 172.16.1.20 which is a private IP address without nat. Sorry, not possible - you can’t have your cake and eat it too :wink: The main reason is that the return source addr 172.16.1.20 will be dropped upstreams.
I want the above rule to work so inside to outside nat and nat to the sever1.
Since server2 is a web server, I like the webserver to see the public source IP, so that logging of usage would be correct.
@Larsa
Thats why I added " if its possible"
Nat rules in post #2 is what you re asking for…
@Zacharias
/ip firewall nat add src-address=172.16.1.20 action=src-nat to-addresses=92.x.x.x
This asks for chain
Same with this:
/ip firewall nat add dst-address=92.x.x.x dst-port=443 protocol=tcp  action=dst-nat to-addresses=172.16.1.20
Sorry my bad, I didn’t manage to complete my answer but the main reason this won’t work is that the return source address 172.16.1.20 will be dropped upstreams since it belongs to a private address range.
@Jotne i missed it, edited my previous post…
Also, in your case, the src-nat rule is not actually needed because you have a general masquerade rule… if you add it though, just place it before the masquerade one so that you can see it works ( packets counting )…
Seems to work on a test router.
