NAT and SIP
I have big problems with SIP VOIP.
I can’t do VOIP over MT with SIP Protocol.
I Masquered my network.
Can anybody help me with the config?
If I use IAX, all work OK.
you may try full NAT,
http://wiki.mikrotik.com/wiki/How_to_link_Public_addresses_to_Local_ones
I use Load Balancing?
I would like use a seperate Internet line only for VOIP.
How I can do this?
It’s possible??
Policy route voip calls to one of the lines (you could even use one static route for your sip gateway) and nat its public addresses to the voip adapter…
We have to know your setup though…
This can be accomplished.
I just paid Butch Evans (http://www.butchevans.com) to do it for me…
We have an SDSL for internet traffic and a T1 for VoIP calls…
With the proper SIP “Flow-Mark” and Routing this can be done and it works extremely well…
My last bit of advice is GET PUBLIC IP’s and SUBNET THEM YOURSELF!!!
It will make your life much much easier!!
D.S. :smiley:
