Could you tell me NAT behavior type of RouterOS?
I found the description for default configuration, but I want to know NAT behavior type based on RFC4787.
http://wiki.mikrotik.com/wiki/Manual:Default_Configurations
NAT is defined four behaviors on RFC4787.
- Mapping Behavior
- Port Assignment Behavior
- Filtering Behavior
- Hairpinning Behavior
I’m not Mikrotik user but new ISP (under discussion) has chosen MikroTik RB750GL2 as router.
I had already asked ISP engineer staff, but they have no anwer ![]()
(They may use only default settings)
Here is other company routers.
| Model Number | Mapping | Filter | Port | Hairpin |
| IO-DATA NP-BBRL | Independent | Independent | Not preserve | Support |
| NEC IX2105 | Independent | Independent | Preserve | Not support |
| corega CG-BARMX2 | Independent | Port dependent | Preserve | Not support |
| LINKSYS BEFW11S4 | Independent | Dependent | Preserve | Not support |
| NETGEAR WGR614B | Dependent | - | Preserve | Not support |
Thanks in advance.
