I have task to resolve. I have two subnets connected with ovpn and OSPF. The first ovpn is ‘‘OVPN1’’ and the second is “OVPN2” and the internet provider gave only private ip address. That’s why I try to use the public ip address for OVPN1 as forward the port to ip address from OVPN2.
What I want ? I want when I write the public ip address for OVPN1 to forwarding to some address from OVPN2.
I want exactly only use public ip address redirect to OVPN2. I using DNAT, but I have problems with that, when I try from some station of OVPN1 it’s working, but when I try to connect from different public ip doesn’t work.
if you use src : 1.1.1.0/24 in your rule , only Request from 1.1.1.0/24 subnet , match with rule and other source address ( from other Internet or source ) not match and cant be get service and redirect .
you only use dst-address field and blank src-address field .
