Hi all,
I have a bunch of field routers utilising the hex poe (RB960PGS) with a cellular 4g dongle as the only way to connect to the internet. All ports are bridged due to the dongle. Playing around while setting up my next batch for deployment I noticed something weird in version 6.2.45
If I enable Nat in the quick config page on initial setup the dhcp server refuses to start.
Additionally I couldnt preference the lte dongle distance over my vpn client connection, under ip>dhcp client the field is blocked for editing. Now it prefers the vpn route. I have to add mangle and routing rules to effectively perform “local breakout”.
It’s not a deal breaker but it changes my ability to automate as I have for 6 months.
