Hello there,
Currently, I have setting up a few NAT Rules between three VPS, one mikrotik and two linux OS
NAT between mikrotik and Linux1 works very well, but between Linux2 it doesn’t work
my current config
Linux1:
eth0 Link encap:Ethernet HWaddr 00:0c:29:75:7c:c8
inet addr:120.20.30.15 Bcast:120.20.30.255 Mask:255.255.255.0
inet6 addr: fe80::20c:29ff:fe75:7cc8/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:21845385 errors:0 dropped:0 overruns:0 frame:0
TX packets:27262728 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:1610196590 (1.4 GiB) TX bytes:6704461951 (6.2 GiB)
Linux2:
eth0 Link encap:Ethernet HWaddr 00:0c:29:dd:18:9e
inet addr:120.20.30.16 Bcast:120.20.30.255 Mask:255.255.255.0
inet6 addr: fe80::20c:29ff:fedd:189e/64 Scope:Link
RX packets:55038 errors:0 dropped:0 overruns:0 frame:0
TX packets:242 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:5243197 (5.0 MiB) TX bytes:27010 (26.3 KiB)
NAT Rules:
0 chain=dstnat action=dst-nat to-addresses=120.20.30.15 to-ports=3724 protocol=tcp in-interface=ether1 dst-port=3724 connection-limit=!15,32 limit=1,5
1 chain=dstnat action=dst-nat to-addresses=120.20.30.15 to-ports=3727 protocol=tcp in-interface=ether1 dst-port=3727 connection-limit=!15,32 limit=1,5
2 chain=dstnat action=dst-nat to-addresses=120.20.30.15 to-ports=3799 protocol=tcp in-interface=ether1 dst-port=3799 connection-limit=!15,32 limit=1,5
3 chain=dstnat action=dst-nat to-addresses=120.20.30.15 to-ports=3788 protocol=tcp in-interface=ether1 dst-port=3788 connection-limit=!15,32 limit=1,5
4 chain=dstnat action=dst-nat to-addresses=120.20.30.16 to-ports=3788 protocol=tcp in-interface=ether1 dst-port=3789 connection-limit=!15,32 limit=1,5
Mikrotik:
[xxxx@MikroTik] > ip address print
# ADDRESS NETWORK INTERFACE
0 10.xx.xx.116/29 222.222.222.222 ether1
1 120.20.30.1/24 120.20.30.0 ether2
All of them have ping between each others.
What’s wrong ?
