Hi guys,
So I have a site that has a RB3011 routing their network. Nothing too complex, a few subnets for different parts of their network and an EOIP tunnel for one segment that links them to a remote office in another part of the city. Everything works as expected. The client decided to setup a streaming radio station as part of their community outreach work and i’ve ended up with a webserver that hosts the stations radio software and webpage via IIS and an IceCast streaming server on another host that does a pile of audio processing and serves client stream connections out. Webserver 192.168.80.94 and Streaming server 192.168.80.55 and everything works fine when connecting through NAT from the WAN side however, although clients on the 192.168.80.0/24 subnet can get to the webserver they can’t get the audio stream from the streaming server which runs on 192.168.80.55:8001. If client browsers are explicitly pointed at ip http://192.168.80.55:8001/stream then the connection works.
To explain a little further, client browsers get to the webserver and are then directed via an
Hope this makes sense, I know i’m probably missing something pretty basic here and guess that it’s being able to get the NAT to detect the port address.
Nat rules in place are;
dst-nat chain=dstnat comment=“StreamingPC-Icecast Incoming Clients” dst-port=8001 protocol=tcp to-addresses=192.168.80.55 to-ports=8001
dst-nat chain=dstnat comment=“Redirect LAN Http to IIS” dst-port=80 log=yes log-prefix=“Radio HTTP” protocol=tcp to-addresses=192.168.80.94
Any help appreciated.
