I just create a NAT for MSTSC connection, It is works but I want to permit only for 1 IP, Where is the settings for it.
Can somebody help me?
Thanks. (CCR1009)
Thanks. (CCR1009)
This thread is pretty old already - if the problem still exists, perhaps you could post your config?
It doesn’t work yet, I postponed this problem.
Maybe I comeback later with this…
add the desired IP to the src-address of your dst-nat rule.
-Chris
It is working now but i’m not sure if this is the best way,
;;;RDP_MIT
chain=dstnat action=netmap to-adress=102.168.2.50 to-ports=3389 protocol=tcp dst-adress=172.10.10.10 dst-port=3333 log=no log-prefix""
