Good day
I have a mikrotik router board.
I have changed my WAN from PPPoE to a static IP.
But my router can ping its gateway but failing ping the internet. Kindly assist
apr/16/2022 18:58:08 by RouterOS 6.45.9
software id = NYXN-0HT3
model = RB4011iGS+
serial number = XXXXXXXXXX
add admin-mac=XXXXXXXXX auto-mac=no comment=defconf name=bridge
/interface pppoe-client
add add-default-route=yes interface=ether1 keepalive-timeout=disabled name=
pppoe-out1 password=XXXXXXXXX use-peer-dns=yes user=
XXXXXXXXXXXX
set 0 default-vlan-id=0
set 1 default-vlan-id=0
set 2 default-vlan-id=0
set 3 default-vlan-id=0
set 4 default-vlan-id=0
set 5 default-vlan-id=0
set 6 default-vlan-id=0
set 7 default-vlan-id=0
set 8 default-vlan-id=0
set 9 default-vlan-id=0
set 10 default-vlan-id=0
set 11 default-vlan-id=0
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add hotspot-address=192.168.88.1 login-by=mac,cookie,http-chap mac-auth-mode=
mac-as-username-and-password name="MAC AUTH as USER"
add hotspot-address=192.168.88.1 name=hsprof1
add login-by=mac,cookie,http-chap mac-auth-mode=mac-as-username-and-password
name="hsprof2 Mac Auth"
add name=hsprof3
add name=dhcp ranges=192.168.88.10-192.168.88.254
add name=hs-pool-12 ranges=192.168.10.20-192.168.10.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
/ip hotspot
add address-pool=dhcp disabled=no idle-timeout=none interface=bridge name=
hotspot1 profile=hsprof1
/ip hotspot user profile
set [ find default=yes ] address-pool=dhcp
add address-pool=dhcp idle-timeout=8h !keepalive-timeout mac-cookie-timeout=
4w2d name=USERS shared-users=10
add address-pool=hs-pool-12 mac-cookie-timeout=4w2d name=Premium
shared-users=5
add address-pool=dhcp !keepalive-timeout name=uprof1 shared-users=5
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp-sfpplus1
add address=192.168.88.1/24 comment=defconf interface=ether2 network=
192.168.88.0
add address=192.168.10.1/24 comment="hotspot network" interface=bridge
network=192.168.10.0
add address=X.X.X.X/30 interface=ether1 network=X.X.X.X
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid interface=ether1
add address=192.168.88.0/24 comment=defconf dns-server=5.11.11.5,5.11.11.11
gateway=192.168.88.1
set allow-remote-requests=yes servers=5.11.11.5,5.11.11.11
/ip dns static
"defconf: accept established,related, untracked" connection-state=
established,related,untracked
add action=passthrough chain=unused-hs-chain comment=
"place hotspot rules here" disabled=yes
add action=accept chain=input comment=WINBOX dst-port=8291 protocol=tcp
"defconf: accept established,related,untracked" connection-state=
add action=drop chain=input comment="defconf: drop invalid" connection-state=
invalid
add action=drop chain=input comment="defconf: drop all not coming from LAN"
in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept in ipsec policy"
ipsec-policy=in,ipsec
add action=accept chain=forward comment="defconf: accept out ipsec policy"
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment="defconf: fasttrack"
add action=drop chain=forward comment="defconf: drop invalid"
connection-state=invalid
"defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat
add action=masquerade chain=srcnat comment="masquerade hotspot network"
src-address=192.168.88.0/24
add action=masquerade chain=srcnat comment="defconf: masquerade"
add action=dst-nat chain=dstnat dst-address=XXXXXXXX dst-port=8000
protocol=tcp to-addresses=192.168.88.4 to-ports=8000
/ip hotspot ip-binding
XXXXXXX
/ip hotspot user
XXXXX
add distance=1 gateway=ether1
/system clock
set time-zone-name=Indian/Mauritius
/tool mac-server
/tool mac-server mac-winbox
