I have a CCR 1016 router.
I have 1 provider but with 2 physical fiber connection. On ether1 I have 1 link and in ether2 second link. Both link is connected on internet provider in same switch to the provider.
I create one Bond interface with ether1 and ether2. The internet works fine and from LAN to INTERNET.
Problem is at NAT with port forwarding. I create a rule like IP_WAN_BOND:88->IP_LAN:80. This rule not working.
If I disable BOND interface that rule works without problem.
If you set port forwarding rule in nat, you need to allow that traffic in filter if you use general drop rule. Hard to guess what is set in your router…
WAN1 and WAN2 have same network and same gateway outgoing traffic work fine and PORT FORWARDING work fine
WAN1 86.5.5.2 gw 86.5.5.1
WAN2 86.5.5.3 gw 86.5.5.1
In this scenario port forwarding work fine
If I put in bond I use WAN1 and WAN2 in bond Outgoing traffic work fine but port forwarding NOT work
BOND1 86.5.5.2 gw 86.5.5.1
